I cannot alter the guard other than "guard rolling". It's a 255 at the moment.
305 is massive, can only go up to 295. getting a 10.5 on the front is near impossible with the guard limitation.
You running AD050's now too?
Your going to be ripping up the times!
AD08's
The rule states "Guard Rolling", it doesn't allow for flaring or additional flares outside of OEM.
Not sure how your going to go about fitting 18 x 10 with 285 tyres on your fronts john, even the rears will stick out
But should look epic haha
Lol atleast I can get more than 3 laps in without my gearbox having its time of the month everywhere
Was overfilled apparently, first hot lap it foamed up and overflowed a little out the top breather. Not something I was proud of but at least it made it through the day for once.
Good feeling overtaking GTR's. :)
It's just over 10mm wider than current on the rear and 5mm on the front (won't need the 5mm spacer I have atm)
No, DarkChild = Leonard Foong, Kuala Lumpur, Malaysia.
Ah different guy
Who was Darren then?
I remember he was a vic member that originally had a 32gtst then bought a white 34R and had the crash in Malaysia and passed away
Ah different guy
Sorry to say, I don't recall a Darren...
Was this recent or a while ago?
A while ago, I think his English name was Darren
real name is Chong Hwa Meng
Story of accident
http://ondscene.my/kemalangan/2-maut-nissan-skyline-putus-dua-rempuh-tiang
There's a frontera in a purpley gunmetal, no black.
http://carsales.mobi...ils/?R=13563801
holden version doesn't look as good for some reason. not a fan of the removeable hardtop either
wanna go check this one out. so clean
http://www.gumtree.com.au/s-ad/ringwood-east/cars-vans-utes/1992-isuzu-mu-turbo-diesel-merlot-red-turbo-diesel-4x4-su-manual-4-x-4/1012558927
here ya go
how cute is it!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
