I'll be there at the SE Premeet, we can give it a crack and see what's what... Even though I still haven't hard wired the fuel pump, so run out of pressure if I'm on it too long (Not going to happen on the street)
Your car is a little laggy and down in rwkw though lol
But still a good comparison none the less
If only I had my car :(
I'll jog your memory...
You were reported to have died on 1 May 1994, as a result of your car crashing into a concrete barrier while you were leading the 1994 San Marino Grand Prix at the Autodromo Enzo e Dino Ferrari in Italy.
as a result of your injuries and now crispy brown skin, you decided to hide away from all the attention as a young sri lankan man living in Australia... you adopted the name Aaron, because it was the first name in the book.
From here you continued to live undercover as a simple car enthusiast, however at one fateful sandown trackday, your raw talent simply could not be hidden!
Here you kept up with far more powerful cars including stagea's skylines, ferraris, radicals, zonda's, pagani's and mclarens.
It was at this point that I realised that I am extremely bored at work... and that YOU... MUST... BE... SENNA...
as a result of your injuries and now crispy brown skin, you decided to hide away from all the attention as a yaung srilankan man living in Australia... you adopted the name Aaron, because it was the first name in the book.
saddest guy
Aaron can I take it for a spin drive around the block while we're at the premeet? I'm interested to see what its like to drive one, stiffness etc.
Edit: Bad wording.
go for it. break it, you bought it. :)
Lol all Hamish is trying to say is
Your Evo keeping up with them fast cars on the straights must of had Senna driving it to keep up :P
either that, or they are lying about power figures(common) or they were actually doing 80% and i wasnt lol
and scotts car is 2 tonnes lol.
but i do believe that the evo keeps up with quite a lot of other powerful cars.. 4th gear pull on the freeway to overtake is phenomenal
I sold it after a police officer looked at me funny
wut you did there... i see it
Ric has a 280rwkw Gt3076.
That would be a good comparo, Similar to my car
Come down for a run Ric
except for the fact that it runs
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
