I'll be there at the SE Premeet, we can give it a crack and see what's what... Even though I still haven't hard wired the fuel pump, so run out of pressure if I'm on it too long (Not going to happen on the street)
Your car is a little laggy and down in rwkw though lol
But still a good comparison none the less
If only I had my car :(
I'll jog your memory...
You were reported to have died on 1 May 1994, as a result of your car crashing into a concrete barrier while you were leading the 1994 San Marino Grand Prix at the Autodromo Enzo e Dino Ferrari in Italy.
as a result of your injuries and now crispy brown skin, you decided to hide away from all the attention as a young sri lankan man living in Australia... you adopted the name Aaron, because it was the first name in the book.
From here you continued to live undercover as a simple car enthusiast, however at one fateful sandown trackday, your raw talent simply could not be hidden!
Here you kept up with far more powerful cars including stagea's skylines, ferraris, radicals, zonda's, pagani's and mclarens.
It was at this point that I realised that I am extremely bored at work... and that YOU... MUST... BE... SENNA...
as a result of your injuries and now crispy brown skin, you decided to hide away from all the attention as a yaung srilankan man living in Australia... you adopted the name Aaron, because it was the first name in the book.
saddest guy
Aaron can I take it for a spin drive around the block while we're at the premeet? I'm interested to see what its like to drive one, stiffness etc.
Edit: Bad wording.
go for it. break it, you bought it. :)
Lol all Hamish is trying to say is
Your Evo keeping up with them fast cars on the straights must of had Senna driving it to keep up :P
either that, or they are lying about power figures(common) or they were actually doing 80% and i wasnt lol
and scotts car is 2 tonnes lol.
but i do believe that the evo keeps up with quite a lot of other powerful cars.. 4th gear pull on the freeway to overtake is phenomenal
I sold it after a police officer looked at me funny
wut you did there... i see it
Ric has a 280rwkw Gt3076.
That would be a good comparo, Similar to my car
Come down for a run Ric
except for the fact that it runs
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
