Kebab Joint is alright, been a few times after late night Uni study sesh's etc. Mmmm kebabs.
I believe DRKNTE (focus) owns it.
Edited by kaitoukid
haha lol well i don't know any specifics like that of course, but yeah haha.
fair amount of commonwhores always there as well... more than once i've seen them chuck a skid/donut before leaving :P
and then a drag race from the lights on prinny as well haha
what a convenient position :P
Hey I spotted your old s14 Aaron, man that thing stands out haha. I was getting a lift back to my work, told my mate to hurry the f**k up and catch up to it.
When was this? Last I heard its gearbox went bang! Lol
Aaron is aware
Very
The dub place?
dont tell him nick.
I'm in, not sure how it will compare to the epic one on Brunswick st :P
patrick is aware
drove the car around today, went to eltham, drove back to my area no worries then..... car just stalls, fuel pump not working.
cousin flat tows me back home (was a 30second drive from home lol) and we get stuck into it
turns out someones chopped the old loom and fitted crimp plugs? bigger pump maybe? anyway. messed up the earth so i had to follow it back and re-earth it.
i f**king hate wiring
lol, guess I'll be looking out for that girl in your dp tomorrow at gokart??? :rolleyes:
lol look for the most stereotypically Asian guy there.
I will be there on my R pending weather.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
