Matt, look for an e30 323i John Player special and dish it out with wide-ass gold BBS meshies....
P plate legal, period correct winning on a budget
Damn, I now want a BMW... maybe I should just steal mum's and modify that...
How much do they go for? 10k?
E30 323i? should be 2-4k (not 100% it was $4-6k a while ago).
Well I was going too but he was debating whether or not to give me the High-Powered Vehicle fine for P Plates. I had my reasons for it and he eventually conceded that he wouldn't give me the fine. Fancy that, stiffing Pettett on a fine he so desperately wants to hand out. Still pissed though, don't get that fine so instead he reams me for a legal height car but still have to get a rwc. He's as big of a toss pot as people say he is, came up to my window and just took my license and didn't say anything. Absolute rude prick.
I'd be annoyed too if I was doing the same job for 7+ years :P
He got me in 2006 in knox, he has been at it for such a long time.. Imagine the amount of imports he has seen over the years... Must know every trick in the book!
His coworker tried to tell me that Pettett is so good at his job, and knows so much, that if he was to stick his head under the bonnet of a mechanics car, he would know more about the car than that owner would. Tried very hard not to laugh in her face.
She said that?!
I'd rather see my taxpayer money for her to copped up in kitchen.
he's NOT good at his job at all....
he completely creates his own strategy and disregards apropriate policing.
The only skill he has is knowing how to manipulate the laws to rasie revenue and pursue a small minded personal vendetta
she's a bitch too
Where do you go? My lovely
where do you go oh oh oh oh oh-oh-we-oh
I wanna know, oh oh eh oh
nfi, second time ive been. western port somewhere
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
