in other news...
FedEx should be bringing my ipad mini case today, and my ipad mini and nexus 4 on Monday. Such excitement waiting for deliveries! But then don't wanna leave home in case you miss it!
in other news...
That's why I always get stuff delivered to work, no chance of it being missed :P But then it sits on your desk and you have to resist the urge to play with it until the end of the day...
Got some 2nd hand injectors delivered once... still full of petrol... People in the office were like "Can you smell something?".... "Nope?"
DENY DENY DENY!
You need a manicure and a manual car. GTFO.
Delivery attempted; recipient not home MELBOURNE - AUSTRALIA 09:49
Fail.
Ah well, not like you could use a case over the weekend without the ipad anyway :D
DENY DENY DENY!
Fail.
Haha if only I worked FT!
Damn it, I missed my delivery FFFFUUU. They came at 10:52am apparently. Before I even posted that this morning!
I left the tag that says "PLS LEAVE IT AT DOOR" just in case this happened... but I dunno what time I did. It was definitely AROUND 11... have a feeling I was like 5-10min too late or something. URGHH. (Yesterday they came at 1:15pm so I thought I was all good!).
Haha I got it for my dad (his bday is on Sunday). Was going to have to give him the case... and tell him he'll have to buy his own ipad (since that's not coming til Monday... but he doesn't know that)
But now I have nothing to give on the day gg.
Looks like I'm not leaving my house Monday.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
