Just went for quick ride, sports bike position is hard on the neck.. Or I'm doing it wrong
for me its worst on the wrists when going hard, when cruising i just ride 1 handed lets you sit up more and have a straighter back
Hey Birds
Christy Jacobs ring a bell LOL
lol fark off, that's twice now. Haven't had two degrees of seperation with anyone else...you must know a lot of people.
She wasn't Asian either, I call shenanigans!
Lol I don't know just asians
And I have a feeling this won't be the end of it!
Yeah but Asian degrees of separation are easy...you got the big 3 suburbs to make connections. You start bringing me white girls and I'm asking questions...
How do you know her anyway? That was a real nice group, lovely friends.
http://www.carsales....%5d&sort=~Price
Someone please tell me how this is worth 55k.
apparently the owner thiks its worth it due to the "24,000 original kms".
no plates, unregistered?
i personally wouldnt pay that much.
but if you crave neat 33's, and can afford to put it in the garage, could become a collectable.
Ahh her hens night, Michaels sister went to. So I saw you in photos lol
Ahaha I'm gonna be haunting your Facebook forever.
So Michael and his sister had a bucks and a hens on the same night? Haha. They needed me to do 7-9 aswell, hence couldn't make it to yours :(
Guys I'm still confused..... soooo Bird's a stripper/ lap dancer/ exotic dancer/ whatever you want to call it???
And no, I'm not interested for myself lol
Life drawing for hens parties. I take all my clothes off, 10-25 hens draw me in a variety of poses.
rofl,,,
my guess is the wife has demanded he sells it so he has put it up for a price that will never see it go
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
