#4, lawls. That was the one where to earn a spot he raced in another BSB 34R... but in the list of cars he chose was a 35. Luls.
Also just saw this on fb (soz no fb brahs)
Pretty cool hahah.
90% sure one of the curators is my neighbour
Call her by her stage name and see what her reaction is lol
f**king truck backed into me and did a runner, bonnets f**ked. Grilles f**ked
Fark, bad luck brah!
Ill do that when I see her tony.
was getting some food for the old fella, turned around before I got my kebab, truck was there, walked out and noticed my bonnet ajar and the truck flying past me, got hos plates and two witnesses.
sweet
I was thinking more along the lines of European car brands.
or drinks
Cristal: The name's Cristal, you know like the Champagne.
Huey Freeman: Cristal, that sounds like a stripper name. Might you be a stripper, Cristal like the champagne?
Cristal: And what would you know about strippers little man?
Huey Freeman: Not much, but I do know they're usually named after liquor.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
