you raise a photoshop with the most played out rims of the last 2 years?
epicfailphaggot
And that horrid factory kit..
I'll give you that it did look good when white. Although his engine bay still is, that must be some consolation?
Nah that's just lazy.
How ya legs Leigh?
feeling alright atm, just got back from a ride and tested gopro out, so dark through the hills hahaha
edit: I'm sure ill feel my legs tomorrow don't you worry child
Edited by UNR33L
Motherf**ker...I was around when AP was rocking a Winnie The Pooh keychain and a hot gf. Basti had a car blacker than him...James Kung existed...Kris was cool...
this never happened. noob
AWKWARD
they broke up for a bit, so you are half way right. which is just another way of saying completely NOOB
So what causes those wobbles? Rears sliding then catches grip?
/noobbikelineaustralia
Wind, road surface, suspension settings...lots of things. It originates from the front tyre though. Something about the front tyre oscillating on the turning plane, starting small and amplifying very quickly into a wobble with little warning. Steering dampers come factory on a lot of supersports to reduce or prevent it.
Also called a tank slapper because the handlebars literally go from full lock left to right, sometimes contacting the fuel tank.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
