I'm guessing if you rode it quick enough my bike would see 150-160 on some of the straights.
on an R1... more
driving through there in the 33 "obeying" the speed limits and all rad rules I would "assume" there are parts I could get to around that speed, of course there is no way you would be looking at the speedo lol
me? not at all... I used to be a pro-am freestyle skiier... no fear there and no cage.
After bombing 50ft cliffs and landing between trees, rocks etc every day you lose the fear until something happens that stops you.
A few of my mates had serious, serious injuries (talking broken spine, full facial reconstruction etc) and then stopped, but until it happens to you, you never learn.
I ended up leaving the sport due to politicts and the fact that the coaches took all the fun out of it.
This is the reason that I have never bought a motorbike.
I have a very blurred line when i'm close to the edge and I always step over it because I am so used to being able to bring it back. If I had a bike, I know I wouldn't be here now
Wow it's too early in the morning for long posts, ill read later
new series of come dine with me (UK) is disturbing...
after a few years they have worked out the formula that people want, it's not good food, it's trashy scumbags lol
I have seen 2 eps of this season and so far 1 had a DISGUSTING 49 year old brittish slag solicitor with teeth straight out of a family guy british pisstake that was just a filthy whore that hasn't had it in years, so she was constantly talking about sex which was sickening... and the other involved a 30 year old dude making out with a 70 year old woman, over nad over again....
I've given up. I'm just gonna maintain it the way it is, might do coilovers and better tyres.. But after that I think it's time I thought about moving out
Mmm to rent or to buy?
Which area you thinking?
Come move next door to my house lol
Oh yeah drop some of Alvins Honey pork at my house :D
on an R1... more
Yes, however Rimon asked what sort of speeds we saw on those roads and on that particular cruisy day we saw some motorcyclists doing what we can guess is around 150-160...
Or 200 using the police method of estimating speed...i.e. pick a number between 1 and 300.
Hopefully to buy, not too sure, have only started saving.. So yeh. Porky finished, I'm waiting for him to make more lol it's fkn amazing
My bad, they use camouflage and radar to cure rather than prevent
http://m.adelaidenow.com.au/camouflage-cops-go-undercover-to-spring-speed-trap/story-e6frea6u-1226574886387
Love the bullshit line about the rest of the sections being too hard to enforce, so they stick to the downhill dip that everyone does a few km over through...
Fkn lol. What a joke
Pretty good time to buy I think, house prices seem to be stabilizing and interest rates are low
Alex can throw in his 2 cents!
Yeah Alvin said he'll make more so I can get some too lol
Well he best be making three sets lol. I told him if pay for it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
