I thought so too, walked into his front yard, saw it, jaw dropped at how shiny and clean it was. After inspection told him, look I'm not gonna lowball you with 6k if you tell me your price so what do you want for it.
He goes "Nine Thousand".
I put out my hand and said Deal.
Didn't even want to bargain on that tbh just took it, had 3 other guys coming that day and wasn't gonna talk him down to have him go "Oh I'll see what the others say". Definitely a once in a life time buy for a 32R that's for sure.
You did not see what I did there...
Nonetheless, well done. So, one RP built 26 coming up?
I need to book my car in there soon.
$9k for a r32 gtr hey
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
