:D
and on a sad note my PS3 seems to be f**ked :(
Very nice...so sad that they'll be black with dust/grime in a few weeks :(
These turned up today, tyre porn :worship:
My Xbox is fully functional :thumbsup:
ahah damn nice :D
ahah lucky!
i sold my xbox about 2 weeks ago - never played it in the end =/
now im thinking maybe i shouldnt have since ps3 is f**ked..
gonna need to buy another soon =/
I have a brand new leather glenlivet satchel that's almost a briefcase just has two clips instead of zip if it''s any help?
sorry brus, not quite what I'm after.
ahah damn nice :D
ahah lucky!
I'll see you my box cheap cheap....but seriously I'm contemplating getting rid of mine, only use it as a DVD player
haha thanks for the offer but i prefer ps3 cos it can play all my blurays
so ill just need to grab another
i just play xbox at friends now lol
I'll take you off the line with these on...then we'll do another once I visit Race Pace :)
Unrelated: why is journalism reputedly difficult to get into, when people write articles of this calibre?
http://m.nzherald.co.nz/nz/news/article.cfm?c_id=1&objectid=10869624
During an interview on Austereo's Triple M radio station's breakfast show yesterday during he was asked why, with his "whole life in front of you'', he would choose to become a a "troll of the highest order''.
I thought primary school would be a prerequisite in that field of work; I was wrong.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
