Yeah got him on the case already, his response time is amazing, already got a price lol and I emailed him about 10 minutes ago
He is cheapest that I've used, cause less overheads. Yeah his response time is awesome fast, especially considering how many people buy through him
Day off!
Yessss
I scored one as well, hopefully tomorrow too :P
I would like tomorrow off aswell. Waste though.. Can't do anything in this heat
Haha stalker. Where you there?
Bought a PVC cap to plug up the intake pipe for a boost leak test :P
lol guess you didn't notice the SAU card I left in your drivers door then
Also day off for me today. Just had to skip some lectures ;).
Woke up excited for Top Gear ep... hadn't finished downloading. Extremely disappointing dl speed dunno what happened. Torrent had good ratios too... Oh well, no matter. Will be done by the time I come home from gym :D.
Worst working outside at the cemetery, no shade heat reflects off all the monuments and stone gets super hot, literally burn yourself it gets that much heat soak
Hey sKids.
Hey man, hows QLD?
Hey man, hows QLD?
I'm guessing the sun is dead hot in the cemetery...
QLD is pretty good. Awesome weather over the weekend for once. It has been 3 weeks of solid rain.
why are 300zx's so cheap is it coz no one wants to work on them?
would it be best to go with N/A or TT assuming everything is/will remian stock standard?
300's are so cheap due to the engine having to come out for an oil change.
Flying up to wagga dem Rex planes so small don't trust them
You'll be right, don't worry your pretty little head out.
Oh and afternoon everyone.
Rimon, you're wanting a engine out thing now? Whatever happened to small 4x4 you wanted before?
find that hard to believe...
need a cheap get around wouldnt mind if it had some style still looking for a decent 4x4 most are either just scrap or dreamer prices.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
