If its just for switching between two tunes, I'd be getting an ECU that supported dual tune storage... Or buying an extra PFC (ECU Only) and just swapping it over while at the servo :P
? Trent has a hub dyno which will give different results to roller dyno. (Due to less variables - slip, tyre pressure, temperature etc)
no... no it doesn't. results are within the same range as different roller dyno's
How difficult is it to save your existing tune to laptop and swap between maps?
like opening and saving word docs
lol Leigh might have something to say about hub vs roller.
Awesome, can't wait...though with any luck I won't need to switch tunes often at all.
lol not gonna get into this again.. but a certain supra made 430 somewhere and 348 at chasers dyno the other week, i beat it :D
all dynos are different, who cares it just means you go to the same place when you get work done to see the difference on power curve.
I can have up to 3 tunes on mine, So good for swapping from e85 to 98 and a valet tune :D
Edited by UNR33L
I think what man of beard is saying is that there's also differences between roller dynos at different shops, hence running on a hub dyno will also have the different calibration to a roller or another hub?
All dynos are different. I don't think hub vs roller has all that much to do with it
Spend a few $k and get a Octane Sensor and an ECU which'll let you flex the hell out of the fuel with anything you like.
Half 91 octane and Half diesel.... Will make Nick so jelly :P
For an R33 GTS-T that I've already over capitalised on...this makes lots of sense!
Haha not really, 91 is still more expensive than diesel atm LOL
More variables are at play when using roller, can't deny that. However the magnitude of impact of those variables on the output is debatable.
Cisco IP phones, you can select background.
unless your draconian sys admin locks it down......grrrr
I tend to change peoples ringtones to the Saxophone tone (if you haven't heard it, try it out LOOL) then lock the min volume to 15(which is max) and watch them rage :P
That said, a lot of those variables are set into the program and a Correction method used to make different types of dynos, temps, diff ratios, pressures, etc read "the same" as each other.
Never works out that way though.
In the end of the day:
If you want to compare one car to another, you put them next to each other on a track or drag strip.
If you want to compare your car to a previous tune, you do it on the same dyno and look at the graph/numbers.
I learnt real quick that numbers mean nothing, especially peak power figures. If you've got no midrange, or torque, you're going to get raped by that bodykitted excel golf with frangipani stickers teh lowz.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
