went for a massive work function ride, so f*kn sore now, back and wrists killing me
started to rain near the end of the ride to the point where you couldn't see 10 meters in front of you.. so we pulled over and did some standstills in the wet :D also didn't realize how much grip you can actually get in the wet, wet riding confidence has improved a shit load that's for sure. Just gotta be careful putting the power on out of the corners
Edited by UNR33L
These wet roads not confidence inspiring at all! I think it's time for an alignment... Where do you SE brahs usually go for one?
Standard stuff, don't need fancy canber settings etc
It's not about fancy, it's about having the job done properly. No point spending money on an alignment if the thing still pulls. Was very happy with the work Traction Tyres did on mine.
Haha well done properly was a given! :P. But at the same time ain't nobody got time (monies) for 3 figure alignment!
Ty for recommendation though, might call them later this week.
Freaking mobile sau, always hit "reply" button instead of "post" button (of the quick reply box)!
OMG, I JUST DID IT AGAIN. After typing that. Go figure.
Traction charged me $99 for the four wheel alignment...I think that's a decent price regardless, but even if it's not I'd rather pay that for a good job than $50 for a shoddy.
Get what you pay for.
Attitude for life.
Doing it right brah
first time I have ever seen some-one get a wrong direction on the indian file btw.....
Lmao i was following the other car. He went right drove for a bit. Stopped and then went offroading.
Jpcr33 and i were liek dafuq
nice, u have a run up against mike? his car would of been loud im sure lol
It isn't that loud to be honest.
:rofl:
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
