I concurr, driving Aarons $230k Mercedes was quite relaxing
One would hope so for that price, or anything $100k plus
+1 for turbo Astras, they have a mad little engine. +1 for Opels in general.
And +1 for FWD. I love me a good maccas tray slide.
Nick I don't know anyone who does those parts...eBay USA is where I'd be looking.
Yeah checked, after a fuel tank and shipping is more expensive than the tank lol
doesn't mean it's not GAY...
Ian Thorpe was the fastest swimmer in aus and he's well gay
LOL
I picked auto based on the fact it's way quicker than the manual. Also I want to keep the car for at least 5 years so as a daily driver good cruiser.
Last 2 cars were manual.
Edited by UNR33L
how much quicker?
all the evo kents used to take their cars to trutrack when I was on the scene...think patricia did too
Then just get him to take the car, I don't see it being any worse if its the same people still working there
centreline are VEEEEERY expensive but VEEEEEERY good
Yeah that's why they asked me who set my car up, as it was so far out of whack he could tell just by looking at it parked in the driveway.
Can't describe the look on his face when I told him it was him that set it up, and charged me an exorbitant amount of money for the privilege.
Also ripped Justin911 off but can't remember the details.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
