Think I've got brake master sitting in garage somewhere, missing the flat bit thingy (to the master) and it's been painted black - peeling though.
Can look for it if you're keen.
nah all good man - though maybe in a month or so ill get back to you about that :P
yeah bspec pads - used them on my gtst and have them on the front of the R - needed some for the rear :P
cusco brake master cylinder stopper is something id like but i guess ill do that when i have some $ to spare lol
its a nissan water pump :P
i was thinking of staying with standard and getting racepace to modify, but dat purpleeee mang!
Nissan N1 Water Pump?
Lighten your wallet just for purpleeee coloured cam gears :laugh:
You must earn a bit :P
http://www.ferrarichat.com/forum/288gto-f40-f50-enzo-laferrari/277182-what-best-turbo-upgrade-f40.html
discussion on what turbo upgrade will be best for my F40... featuring such gem's as:
  • Alot of people go with ball bearing units now
  • Ferrari themselves do the best upgrade for the F40. At least I know they used to. You give your F40 to them and they upgrade to turbos to larger ones which ups the power from 478 HP to 600 HP. Top speed rises to 220 MPH. Send Ferrari an email to see if they still do it.
  • The most popular larger turbo upgrade. Garrett "roller bearing turbos"
  • he original owner bought the parts for his F40 racing projekt in Italy and had it converted at a local specialist. Would be also my way to go for more performance on the F40.
  • Up the boost to 2 bar and you'll see 600+hp
  • I have yet to see any aftermarket upgrade that works better than the factory turbo's.
i may infact read more threads
And he still owns, and has the money to mod an F40.... While you're reading about it :)
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
