From these images we can see a lot of flex in the wrist for maximum whiplash. Top image uses the elbow for control and most of the momentum, while the lower image goes for the all-out body and should force behind it.
I watched that
Then I thought to myself
Why stay in a relationship where you are getting beaten every day?
The only person that could of helped her was herself
This, women logic is stupid
Also I think she is Serb/Croatian with what she wrote at the end, those bitches be mega crazy
Wayno I think.
Yeah Wayne, RCHOO
That chick's boyfriend is incredibly ambidextrous. I saw a left eye and a right jaw in there. Photos also appeared every 28 shots/days or so, suggesting to me that she was the one starting the fights. Couldn't stop staring at her mole either...I was waiting for it to disappear in one of the photos.
Seriously though, will never understand hitting your partner. If it gets to that point, why are you still with her. There are some tough situations for the girls though, like when people have children or they might be business and relationship partners with capital over the house. Newly married people can seperate but can't divorce straight away, so shared assets like house can't be split. Some girls feel trapped in a relationship and like they can't leave cause they love their partner too much and depend on them to live (look how much it happens in non abusive relationships)...then the guy makes them feel like they're worthless and can't do anything about it or threatens to kill them if they try to leave. That would be pretty f**kin scary IMO. Seen firsthand how far some females will go in a relationship, no matter what the guy does, it's crazy. Creatures ruled by emotions.
hahaha yeah I was staring at the mole mostly, reminded me of Austin Powers. Moley, moley moley...... MOLEEEEEEEEEE
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
