DiMattinas is decent on Lygon St.
Cheers for the invite but tired of being third wheel
/dat single life with couple friends ~_~
Kebabs only eaten after midnight. Fact.
Have misfire at high rpm.
Looks to happen after long drive. (Wasn't showing signs at dyno day)
Obviously misfire occurred after tune.
Currently have splitfires, new coilpack loom & optima yellow top.
Running bcpr6es-11 (11mm gap)
Booked in for a review with Trent on Wednesday. Could my issue be spark plug choice (wrong heat range or gap) or a tune issue?
Not sure if I should change plugs prior to trents...
Awesome sticker
relevant to my interests
http://www.ebay.com.au/itm/I-LOVE-HEART-MY-R33-STICKER-DECAL-4-NISSAN-SKYLINE-JDM-DRIFT-RB26-GTR-GTS-GT-/200817373922?pt=AU_Car_Parts_Accessories&hash=item2ec1a5f2e2
that guy also has i heart fg/bf/ve/s chassis/r chassis/subie/honduh/rx.
If anyone can point me towards somewhere i can get a large vinyl wall sticker of a r33 i'll give you all of my internets
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
