I got a few planes I wouldn't mind detailing for $50 - $200
4d7703cb2a8446ed84285f88767f1341-Airbus-
He said "car", don't be unrealistic ya dick. That being said, my uncle would like to take advantage of his upper price limit
Michael, I have cleaned one of those Enkeis man..lol...i'll do the other 3...next year...
Oh? I thought you might've already put them on a car. Have seen an Accord with the same Enkeis in Doncaster area quite a few times.
i think i have seen it...its a dark grey euro yeah...funny you should say that cause they are probably going on my missus Accord :P
I have tyres for em...the offset is fat on it too, fills the guard nice...problem is as yet i'm not allowed to lower it and without low it will look like ass.
QR scanner, you need app for this?
it is an app...search for scanner in apps
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
