My bad, it's actually the LSA, which is similar to and based on the LS9...but made for the Camaro ZL1.
FWIW, from what I read, standard boost on the LS9 with 476kw is 10psi. Guessing LSA runs ~5-6psi.
Yep, I called the use of the LS9 :D
Was the obvious choice without building their own engine...
Which is good news, because the same engine appearing in the ZR1 Corvette has 476kw and 819nm (!!!) of torque. HSV pulling their usual detuning tricks methinks...
I reckon that acceleration time will be conservative...unless they have it hooked up to a shitty transmission...cause even 2 tonne luxo barges with 400kw+ are down to 4 seconds for 0-100. In any case, there is no replacement for displacement, so if you got the cash to burn it'll be a better starting point for tuning than the GTE.
inb4 Leigh loses to one on the street :P
Bring it on!! :P
Looks like it's intercooler and pulley time if that hapens!
Previous HSV autos have been sheit, and manuals are just slow for drags compared to a good auto.
Yea ZL1 has the same power as the HSV will have 580hp or whatevs
Get a real engine like the Mustang GT500 :P 440rwkw ftw!
LSA only has 1.9lt supercharger as well (same as mine) whereas the LS9 has 2.3lt supercharger, then you got the difference in heads cams etc. LS9 also has forged internals and LSA doesn't :P
Edited by UNR33L
see Aaron knows ;)
it was pretty bad, scratched up n shit..not something I could fix in an afternoon...but had a crack at it...
then after taking about 4 million photos I find out I need a new camera cause they are nearly all blurry... :rant:
I also advised him to invest in some black paint for them wheels... :P
#@ARTZ Are you located in the east side? Might need a polish/wax detail or whatever you want to call it as my paint is stuffed after a trip to Phillip Island.
Got these weird patches all over the car and can't wash it off for some reason...
yeah bud...in Frankston but can work anywhere...
also were you on GOR cruise?...I think i have photos of you on the freeway..
Probably oxidation
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
