Motorsport hath defeated me once again. suspect a spun bottom end bearing :(
was a good day though, 4 groups makes for a fun round.
Build time!
it's already built :( I ain't gots no money unless the other pulsar sells
Gf didn't end up having vegieterian, she had Curry chicken Laka and I had a curry rice dish with prawn and chicken.
Banana fritter was okay, tried soy milk with jelly and soy pudding.
Coffee with jelly was interesting, never really tasted anything like that before.
oh no!! dude you were flying around that track....i think we got some footage somewhere...but that little car tears up the main straight...I though you were going to catch that silver rex
high boost I would have ;)
need to lower camber for sandown, had no traction
that explains why it looked like it turned in nice...what you get a 1;34 or something...faster than me, maybe i need moar powah!!...
bloody richo knocked like 5sec of his PB with a f**ked diff...that shit is ridiculous
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
