some guy tried to grill me on an email and CCed my manager and branch manager
cbf writing a reponse on iphone but tomorrow morning I'll definitely be returning fire pissed me off especially when I'm not in the wrong
I wanna see this shit...love office politics when I'm not involved.
Yep some people need a clue.
Never met the guy but apparently he's old, so why try and grill a young guy that knows what he's talking about when it comes to technology? Should of just called me if he had a query for starters which he didn't. Apparently "wasted" him and another guys whole day trying to figure it out. Should of taken 20 minutes if he followed my simple instructions. Makes me angry over such a simple stupid thing. I bet the managers are laughing no response from them yet.
I'll laugh with my boss tomorrow about it for sure.
I'm tempted to login to his webmail to see if/what his manager responded to him with. Don't mess with us I.T folk we have our ways :P I wont though.. have morals!
Edited by UNR33L
Never knew Repco made filters.
On your skyrine? Any problems or difference?
Just need to change oil before deca this weekend.
yeah repco on mine...from what I've been told by guys that have chopped them up they are actually better than ryco filters....also a couple bucks cheaper....
Some Autobahms/bursons Have Greddy oil Filters. I Quite like them
Goodes is a pathetic little bitch who needs a good belting...
You guys have called me an ape/gorilla before due to my beard and did I complain / storm off like a bitch? No... Because unlike goodes, I am actually a man
Puts on tin foil hat....
There is also the distinct possibility the media have blown this out of proportion in a deliberate attempt to take the attention off the improper treatment of the 13 year old at the hands of the police...
Removes hat...
haha can only imagine how much fun you can have when you control the I.T
Im friends with my IT support. In return full admin rights on my laptop...woo! /installalltheprograms
You guys have called me an ape/gorilla before due to my beard and did I complain / storm off like a bitch? No... Because unlike goodes, I am actually monkey magic
fixed...
haha yeah sometimes has its advantages, if people are nice i do them favors
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
