ATO says capacity over 5L too :nyaanyaa:
That's just to possess or manufacture a still. From what I interpret, if you're using it to make alcohol in any quantity, you need a licence and to pay duty on it...which at 40% alcohol volume is $20 fkn lol
properly designed still, on a large enough plot of land, should be undetectable.
but you'll have to do multiple pot stills + zeolite to break the azeotrope, i could run a hysis simulation and give you a rough guide regarding the sizing of a reflux column, when i can be f**ked. too much deadspace 3 to play.
well technically yes...its illegal for it to be operating in your house making alcohol...but really who gives a f**k...there was police at the home brew meet the other day...they dont care..
This all went in one ear and straight out the other :/
making gnocci at home is not something I do on the reg.... maybe 2-3 times per winter lol
it is a fair effort, however awsesome when done correctly though...
I wanna get into making my own beer... I drink too much of the shit to keep buying it lol
I've made my own gnocci a few times and it's the best!
you have green card? ok ok i love i love!!!!
Tease Maggie with this one LOL!
Speaking of burgers, anyone tried Mr Burger?
Multiple times, it's not that good, should not be in number 8 spot with Huxtaburger in 10th. It's not bad, but not something I'd go out of my way to eat often (only had it a few times coz the guys at trade school don't mind it every few weeks)
Trying to ween her off it? You shouldn't need to try get her over her ex. If she isn't over him she isn't ready for a new relo.
That's it right there. Get out now while it's been made easy for you.
It's not that hard for me to give him the wrong advices
OVpqSktOczFRc00x_o_pumping-iron-by-arnol
Excellent post.
Had some porsche with the plates RS997 try to give me a go the other night on nepean highway... was even... there's no way it was an RS.. didn't get a look at the back of it to see what it actually was...
Just saw him looking angry afterwards before he turned off to go have a cry about the extra $100,000 he wasted on his slow porsche.
It's always the rich cars and commodores that want to race me :/
Sure he was trying? Unless ya skyline is pretty quick Porsche > skyline
had bucks on saturday.....we now at 2 ppl in hospital due to it success!
haha nice!
F&F 6 was decent
yeah heard wasn't too bad, so will watch
Got a sick F&F cup with my combo too
Saw those they are pretty cool
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
