No preference, they seem to have shops all over the place these days anyway, all with 30+ courtesy cars parked out the front
Well, I've had bad experience from the Deer Park one along with another member here. The owner or in charge there is a young guy which tried to milk my money and did apparently stuff another members car on here....
Thinking I want a GS now...I'll let Leigh post his times lol
Haha yeah good quick daily with no cop troubles :D
So yeah was 2 degrees up at heathcote and track was very dewy and glazed they had to call it off just after 9 so only got in 3 runs.
first run was just sussing out the track 12.2 @ 126mph with a 2.2 60ft, really just let off line slowly.
2nd run did a 11.61 @ 126mph with 1.85 60ft (more like it but knew it had bit more in it)
3rd run bit later in the night again and you could really tell track wasn't up to scratch 11.8 @ 126mph with a lot of wheel spin then that was it.
I had the gopro on helmet so i'll post up my 11.61 run
Apart from ripping you off how was the workmanship? I'm not paying for it so cost doesn't bother me
Not too sure about the workmanship as my stolen car was towed to them until my insurance picked it up, just glad I didn't have to deal much with them.
Been to WestWood Auto Body Shop on Westwood drive, while their customer service was good, their workmanship wasn't the best. Having to get them redo my car twice before getting it to a decent level.
First visit, the rear bumper wasn't repaired properly as the cracks in the bumper were still visible. Second time it had about 3-4 drops of clear coat almost the size of rain drops...
If they're willing to be dodgy in one aspect of the business, I'd be concerned about their attitude towards other practices like workmanship too...likely have apprentices working on your car and save time cutting corners etc.
Like those horror workshops who charge people 50k to tek screw their body kits on.
11.6? damn. what tyres?
stock engine with bolt-ons (injectors, turbo, exhaust and ECU) won't crack 200 and still I cost me $600 for a tune. I'm thinking its worthy getting work done on it now while it's out. the block still requires machining to convert to FWD
got call from engine builder last night... spun 1 bearing, scoring on saddle and caps, cam lobes and springs damaged... sounds like I might have over-revved it too :S which I kinda remember doing at sandown. my shift light should get chucked in once back on the road and then get an electrical-cut rev limiter...
Street tyres nitto nt05
I reckon with some proper slicks on a good night would be very close to a 10
I love how it was one of the quickest there and I just drive home :D apparently it was pretty funny cos of how quiet the car is compared to the ones I was racing
Edited by UNR33L
Saw you drive past me Thursday night as I was turning into Knox you gigantic phaggot
Home Alone didnt have a plot twist.
Lost In Translation didnt have a plot twist.
Monsters Inc. didnt have a plot twist.
Every Stanley Kubric probably didnt have a plot twist.
Oliver Twist didnt have a plot twist.
Twister didnt have a plot twist.
The Plot To Kill Hitler didnt have a plot twist.
Joey and the Plot Twist didnt have a plot twist.
Home Alone - kid got left home alone
Lost In Translation - when bill murray's character meets a chick you expect him to fall in love with she instead makes him remember he loves his family
Monsters Inc. - the monster realise that scaring children is bad
Oliver Twist - after getting kicked out of the orphanage he ends up around criminals, which in turn reminds him that he doesn't want to be like them
Twister - dude is trying to divorse his mrs because of her tornado obsession, but then ends up chasing tornado's with her
Every Stanley Kubric - the shining.... is just a series of plot twists joined together. clockwork orange has alex turning good and then bad again. full metal jacket has private pile commit suicide
The Plot To Kill Hitler - hitler was in a room of trusted officers when one of them placed a suitcase full of explosives next to him (albeit on the wrong side of the table leg) after surviving this hitler became much more cautious.
Joey and the Plot Twist - this is just something you made up.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
