Had number 7 on the list last night, Belle's diner.
DIsappointing. From the 4 I've had from the 2012 list so far (10, 9, 8, 7) they got the order the wrong way round imo.
Their order
Huxtaburger
Parlour
Mr Burger
Belle's
My order
Belle's
Mr Burger
Parlour
Huxtaburger
These aren't plot twists, they're plot devices.
A plot twist should be a development, somewhat unexpected by the audience due to intentional misdirection by writers, who also maintain elements that support said development fitting logically within the realms of the story arc, yet contrary to the logical direction of the narrative.
Bleh
which one? the smith st one is FULL of hipsters 24/7
lol cnr Alexandra Parade and Smith St on any given Saturday night...always 20 hipsters gathered on the street corner with iPads and fixies.
Their order
Huxtaburger
Parlour
Mr Burger
Belle's
My order
Belle's
Mr Burger
Parlour
Huxtaburger
Rockwell and son's is next on my list... I have high hopes for this one.
I went to the place that's supposed to be the new it joint for all the hipsters recently... "Brother Burger and the Marvellous Brew" and it was shiteful...
Merowyn's brother kept dickbagging on about how it's better than Huxta, so we caved in and tried it... @ $16.50 for a fkn burger I was expecting a LOT... and didn't get much
Lol smith street. It was funny. Me n Jess were enjoying a burger when this girl on some sort of oversized push scooter with wheel barrow wheels and very large chopper bicycle handle bars.
I felt like I'd stepped out of civilization and entered some sort of hippie/artist 3rd dimension.
It was scary
It was scary
oh yeah,,, that'd be because she "doesn't care what people think" :rolleyes:
keep the 20 in there until you can afford the 25/6 box
you will only destroy 20 and have to replace it.
better to be able to sell the RB20 & box as a package or to sell an unbroken box on it's own complete as opposed to small metal fragments
Ill be keeping the 20.
As for the box.
Meh. Gonna go to town on that mdrfkr
CHeers for the sump borci.
Was $67 for 2 of us last night, had 2 burgers each and chips (which I had high hopes for when I saw they were seasoned, but they too were tasteless shit). Whatever the other burger was that we had (had bacon/egg on it, we took the pineapple/betroot off) was better than the signature burger that's on the top 10 list...
Trunk diner is next on the list for me
yeah, they aren't huge.... if you are hungry you do really need to go 2
Would've liked to but by that time it got stupid busy. And looked like people were getting shitty that we were taking up one of their 4 tables lol. We weren't hipster enough.
What's another burger place I can try?
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
