Haha watched both episodes last night
Even uses urine as eye drops. lol wut
She was crazy that's for sure
There was also a girl who drinks petrol everyday for a few years
That was also quite interesting
Yeah all the chemicals were killing off her nerves. She couldn't feel the pin
She looked like a junkie from it though
my sisters always talk about that show.. apparently one lady loved sleeping with her hair dryer. and she had numerous burn marks from it. whatever floats your boat I guess... long as it doesn't harm others
What's the retail on one of those?
PMd Clear your inbox brah
More than you can afford pal. Motorbike.
:domokun:
I don't know what that is, but it looks awesome!! Congrats
Thanks mate! cant wait to ride it
You've got too much bloody money Leigh
Not really will be living off 2min noodles for a while, early tax return present for myself.. :D
Edited by UNR33L
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
