Do epic skids then buy proper tyre.
Film the skids while you're at it.
Planning on buying proper track tyres all around. So Yokohama or Hankooks
Wont fit under GTT guards atm
So need to wait till I get some GTR guards
In all seriousness, just inflate them to normal pressure (36psi or whatever you do) and drive around, keeping an eye on them over time.
With 235s I reckon it should be fine if you go fast on corners if the profile is 40 or 45.
I'm sure someone will correct me.
Edit: what size/offset are the wheels?
235 on 9.5 aint even stretch doe. Normal tyre pressures will be fine.
Cheers brahs!
Its a 235/40 tyre
AD08
Yoko AD08 or Hankook RS3 is at the top of the list
Yoko AD08 R would be even better pending on price and availability
Otherwise NItto NT05, but not sure its performance as a track tyre
im looking to grab another set of AD08s or something similar also, road tyres im using at the moment (falken FK452) are awful with road noise.. and one of their claims is they eliminate nearly all road noise.. i hate them..
Thats not stretched much tony.
Just run 40psi if you wanna take corners like a mad kunt
Hokie dokie!
Can't go wrong with AD08's
Just kinda hurts the wallet unless you know a cheap place.
AO50 or gtfo :P
When I'm a pro driver like Richo ill get a set :P
Falken 452s - typical of a silica based tyre, great for the first 50% of their life, and then just get noisier to the point where they are unbearable. Plenty of reviews saying the exact same thing IIRC.
ahh this i did not know!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
