Think my parents have 24. All comes down to how good the inverter is I believe
Panels come in capacity from 170-250w ea.
4.9kw used to be the bigest ud see on resi. As thst was the limit for prem feed in (60c). But thats gone now.
Much more than 8kw and uve got a load of panels. Generally not enough room on most roofs.
If ur a high consumer or with young kids at home or retired, then it will pay off 5-7 yrs. else for most people its still a 10yr deal.
um, no
getting married just b4 then so will be on the honeymoon
I Have made the call tho.
first track day will be a couple weeks after back the tampered one on cup day
then the nov deca
and then nats at the end of nov.
so after a year off, 3 events in a month...booya
Not sure if anyone knows anybody who in final years studying medicine/nursing, but I've got a room spare at my place near Monash medical centre. $150 a week with all bills, bed + linen included.
Kind of sick of living with full-time students, but something like an intern or final year would be preferable. Will put up a notice at the hospital as I dont think ill have much luck on gumtree with the other 250+ properties...
Richo's famous. Vic time attack coverage on sbs
More to come next week.
Nsw round. Though I didnt have their camera in the car much. Would have been good, as there was some serious sideways action in the cold.
I think all the evos got the cameras.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
