pfft... sif not take the kanye jizz, shove it in some chick, marry her then sue for child support and have a rich-ass kid to mooch off
amateurs
Now I ain't sayin you're a gold digger...
2 more days until full license, finally get to drive my car! If my P's expire on the 24th, does that mean I can drive on the 24th, or wait until the 25th?
i'd start driving now, tbh, bahaha. within reason.
http://aca.ninemsn.com.au/article.aspx?id=8693684
hehe someone has a varex exhaust in that vid. Cops picked up on it; not bad...
Bleh
Typical ACA...put up the footage of low intelligence people swearing contrasted with police showing concern for the community.
I lol'd at cop's comment about it being dangerous to the community because the cars can't stop...didn't see anything in the report about faulty brakes??? Is that the best reason the cop could come up with as to why they defect cars for modifications?
Loud exhaust is fair enough to an extent...can see how that pisses people off. Though it's still overpoliced when the legal limit is ridiculously low, and I personally don't agree with the law.
But the other stuff they are defecting them on...they really have to come up with the worst excuses to justify it.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
