haha was just guessing, no actual math done (slow day too) - then again my car is sitting on 16l/100 i suppose.
I live about 8 minutes from Birds I'd say.. I live in dat dere Wantirna / Knox danger area hence me not owning a skyline
Thinking gym > kebabs tonight..
Only 16/100?
Drive it harder.
Lol, think the most i've ever had it was 16.8 or something keep in mine this is mostly city traffic purrs along at 8 on the hwy
Reminds me need petrol for my bike too, on the way to work this morning light popped up -_- dam you no petrol gauge!
Intel suggests the Coles servos on Bwd Hwy are 149.9 for 91... So 165ish for 98, I suppose.
Haha my bike has a fuel gauge :D... But no clock shits me.
Swap you a clock for a working clutch
i dont know if this is a stupid question for bikes, but dont you just take the cap off and have a look or tap the outside and hear if its empty? its just a lawnmower tank, right? :P
Or light up with lighter.
to some extent you can depends on what type of bike, dirt bikes kinda yea.
my road bike stores fuel even under the seat lol, most road bikes you can only tell when they're pretty much full or half full the other way you can tell is how the bike
rides too
best bet is just use the odometer or wait till the light comes on if no gauge :D
Edited by UNR33L
Still not fixed, bro? :(
Also, can confirm my earlier Intel was correct. 98 was 166.9. I successfully located my 10c voucher luckily.
Nope, only have a cold wet muddy carport to work in, and only weekends to do it. Need to make sure I can have it done in 1 day so I'm not leaving it without a clutch cover
Pretty sure you're <5 min away, if not less, from me then, lol.
Haha I'm at the gym atm. Best of both worlds.
You two are about 500 metres from each other. 5 minutes would be a walk.
Also 10 cent voucher = about $6 in 60L tank
16 cent voucher = about $10
Shit adds up if you use them everytime.
Definitelt worth stopping by Birds' house when in doubt of vouchers.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
