Nah from an insurance POV the Mazda would be at fault due to the bike already being in the lane. The driver of the Mazda should be aware of his surroundings at all times when merging and not just in the prior head check.
Bike hasn't done anything wrong by going in the next lane and speeding up.
ahhh yes. undertakes a car (illegal) then blames car driver because when he looked it was clear.....
waits for shit storm...
Passing on the left on a multi-lane road is not undertaking and perfectly legal
and this is why the drivers in australia are some of the worst in the developed world.
Edited by Plattsy
also last bit of trolling for the day.....
The rider of a bicycle must not ride past, or
overtake, to the left of a vehicle that is turning left
and is giving a left change of direction signal.
technically the car was doing this as he got level with it. so in the eyes of the law he is undertaking and therefor in the wrong....
Whilst I fully agree, I must give in to my inner Ozzy and tell you to 'Gobackhomethen you pommy git' :P
i love ya man! and you know im more aussie than you, cos chevy, but this is ridiculous man... the bike isnt even in the left of his lane! i agree with birds on this one...
May as well keep feeding the troll...
Do you not understand "And"? The car is not turning left -and- giving a left change of direction signal, he's changing lanes.
And most developed countries have the same rule, except it's for passing on the right for the LHD countries.
Yes the bike could have positioned himself better, but doesn't make how he rode illegal
Also he started changing lanes prior to indicating, so still the driver is in the wrong.
True dat.
The first thing I got taught in the HART rider training course was to never sit in a drivers blind spot, and to never travel in the left lane. Car drivers have issues seeing a bus let alone a motorbike in their left mirror.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
