Stock Results @ 14m25s
155HP 127TQ
Perrin Headerback Results @ 15m30s
156HP 131TQ
Ummmmmm, what?
This better do some serious boosts to the midrange, because the Perrin exhaust they installed in this video has a $900USD pricetag?
Am I missing something?
Haven't watched the vid, but I only have a cat-back. It cost me $750 second hand, they're about $1100 new and actually one of the cheaper cat-back options for this car. Made in the USA and nice quality. It would have gained a few kw, I can feel it however if I did the rest of the exhaust it'd gain a bit more. Planning to do the headers, over-pipe, mid-pipe, might need to think about adding a resonator back in as it's already boomy inside the car under any throttle at all and it'd only get louder and dronier. It had 108rwkw stock, 118rwkw with just a tune so with the cat-back added I'd expect it'd be up around ~125rwkw now. Not bad for an N/A 2.0L auto.
fyp for accuracy.
UEL and EL's move the torque band slightly, and although UEL's should lose power they actually don't on this engine. Both make around the same power gain. So realistically it depends if you're looking to eliminate the torque dip or have higher top end and what sound you're looking for. The UEL's do sound pretty hot.
So this happened today...
brakes have been upgraded to GTR ones and they seem to work noice! now I just need to get the biatch started and then nursed all the way to a workshop... or towed to one.
Wo can service a skyline near dandy?
After service... to the paint shop to have the panels all matched up.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
