Yeah, it's not. No easy to use GUI, more features than grains of sand. What I use it for only scratches the surface. It's the type of software that requires weeks of training on, and I've had maybe an hour. Stumbling my way through it.
For a small business I'd definitely recommend Attache, the Inventory Management side of it is easy to use, the Accounting side isn't overly in-depth. I know a accounts contractor recently out of work that knows the ins and outs of it.
my previous employeer went from one system, to SAP, so a different version of SAP, to something else cause no one liked SAP, and then thinking about going to a different SAP or some shit. in a space of 4.5 years.
think someone/people were just trying to justify their existence and/or piss off both the in-house IT department and the out-house IT department. and also piss on payroll... who was originally in-house, then they went out-house, then they went back
corporations, gotta love them.
SAPlinesaustralia.com
lol. hows the training regime going?
yeah but car is sitting in workshop... oil lines still have to be cleaned out, make up new breather/overflow setup. hopefully its not wasted time.
havent you started hitting the gym n shit
SAU boot camp for people who dont want to look like tanked muzzas but be fit and attractive and socially up-to-date with supplements
I'll be joining Aaron's gym for the first time maybe this weekend
Going to get Aaron to get off his arse
And we'll both be shredded
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
