BaaaaaAM. We can repo from behind an unlocked gate, even on private property. But if its locked we need a warrant.
I doubt the police wouldn't be able to If we can..
NZ is worse, lol we can physically break into the house without a warrant and do as much damage as we want to the lock/door/gate/garage to recover our assets lol
Out of curiosity what gives you the power to reposes stuff when its on private property?
I know you can just wanted to know how
Wtf. Why Did that just repost
You're a repost.
9 weeks sorry.
Fact I was told 1 week first of all and it keeps getting blown out more and more is pissing me off.
I bought them from a place which alot of people from melb recommend for tyres/wheels.
Did you buy a GTT also man?!
Shit, 9 weeks... I'd be raging as well!
Yep, I bought 34 GTT.
hahaha bam!
hows ur track 34 going toby? I reckon my bro should just do what you're doing
Engine is healthy.
Just need a bigger turbro as it is a restriction at the moment
Won't have monies for it till next year at least I think
Well it's technically ours until its paid out or the encumbrance is removed, so I guess that's why..
TE37SL's, I also got centercap adapters from a racing sciences and the volk limited edition centercaps, picked up some kyo-ei / KICS revo chro r40 locknuts, not sure if ill end up using them, ill see how they look.
lol I dunno what ill do with the panasports! might hold onto them.. might sell them.. not sure yet :P
Edited by bluejeans
Keep them, then just buy more wheels and become a wheel whore!
Now you need a set of Nismo LMGT4's.
I know what you should do.
Hand over the wheels back to me :P
