BaaaaaAM. We can repo from behind an unlocked gate, even on private property. But if its locked we need a warrant.
I doubt the police wouldn't be able to If we can..
NZ is worse, lol we can physically break into the house without a warrant and do as much damage as we want to the lock/door/gate/garage to recover our assets lol
Out of curiosity what gives you the power to reposes stuff when its on private property?
I know you can just wanted to know how
Wtf. Why Did that just repost
You're a repost.
9 weeks sorry.
Fact I was told 1 week first of all and it keeps getting blown out more and more is pissing me off.
I bought them from a place which alot of people from melb recommend for tyres/wheels.
Did you buy a GTT also man?!
Shit, 9 weeks... I'd be raging as well!
Yep, I bought 34 GTT.
hahaha bam!
hows ur track 34 going toby? I reckon my bro should just do what you're doing
Engine is healthy.
Just need a bigger turbro as it is a restriction at the moment
Won't have monies for it till next year at least I think
Well it's technically ours until its paid out or the encumbrance is removed, so I guess that's why..
TE37SL's, I also got centercap adapters from a racing sciences and the volk limited edition centercaps, picked up some kyo-ei / KICS revo chro r40 locknuts, not sure if ill end up using them, ill see how they look.
lol I dunno what ill do with the panasports! might hold onto them.. might sell them.. not sure yet :P
Edited by bluejeans
Keep them, then just buy more wheels and become a wheel whore!
Now you need a set of Nismo LMGT4's.
I know what you should do.
Hand over the wheels back to me :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
