I still cant get over A45 250kw from a factory 2L.
the day draws nearer when the pulsar can have its arse-handed to it by production hatches and will be the slow 70's hatch equivalent of today
my falcadore will smash a c63 brah! do want though!
nah but srs they are mint, too bad the coupes are more expensive cos they look heaps better than the sedans IMO!
some guy down the street has one, sounds mint as fuark.
loled @ that vid
Apparently that new HSV GTS did a 12.6 with '430kw' in a magazine review
Edited by UNR33L
Not too bad man. Yourself?
Good thanks.
Grandma passed away last night so I think hes going to bury her and then sort out his dads visa stuff and then come back.
That said he's doing everything in lebanon so he wont need to stay in syria
Sorry to hear about your Grandma.
The situation in Syria is terrible in general.
c63 a nice family car in a few years I spose lol
Until your kids are about 3-4 years old lol. They aren't a roomy car.
My business partner has one- best sounding car you can get, great looks, classy and neat interior.
But good luck getting traction. The transmission isn't quick/smooth either, although I think they rectified this in newer models (wet clutch or something like that). Oh and no LSD standard- unless you have the performance pack version.
Time to go for 250-300fwkw in the Pulsar Leroy
That should keep you ahead of production cars for another few years :P
lol car would be limited to dyno queen duties and Show'n'shines. gearbox would be on edge.
...i'd probs go E85 if I wanted more...
inb4 Scotty propaganda
loled @ that vid
You mean your modified falcodore can beat a stock c63. Well done
Good thanks.
The sedans are quite roomy, not to mention the wagons
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
