I paid $33, my mum is a CA and still just threw her arms up in the air when she couldn't get me into refund territory...
Basic Normal Salary, no real expenses, thing that put me into negative was Savings Interest I think.... Need to plan my dodginess in advance for this FY.
I was only getting maybe $100 in interest each month?
I don't know, I don't need to understand these things, that's what my accountant is for :P
Edit: lol definately not that much, I'm trying to save for a house deposit, not to buy a McLaren F1 outright :P
Yeah I just don't know what I can put there!
I don't drive for work, just to/from work...
I don't have any uniform or need to buy anything out of my own pocket for work...
I don't travel for work...
I don't really do any training or anything that I pay for out of my own pocket
We have a Ned Flanders here
birds. whens the monthly newsletter jew mate?
When I can be fked writing it haha. Events dudes give me no help writing the articles :(
Stop doing a good job of holding me accountable!
after a retune from Burnzy with the mr turbo and cleaning up my shit map from CREATD the car was amazing to drive, power all through the rev range and no knocking lol
I can't wait. Just need bank balance to recover before I can throw money at it... :P
Keeping one eye open for a good deal on an E9 turbz etc... hoping it doesn't pop up when I have no money haha. I think this is the most temperamental of my planned round 1 of mods
What about all those suits you had dry cleaned?
And driving your car to visit vendors?
Those logo'd work shirts you were required to buy?
Tax time was good to you Toby?
If your accountant didn't get a good return
You're gonna have a bad time
No big refund, need to find a new accountant
Seems as though as your mum is too legit.
Just like the Matrix, some of the rules can be bent
  • Like 1
go 8mr turbo, cheaper to buy and direct fit
9 turbo needs a fitting kit which is another $100ish, not worth the hassle imo
/watchedtoomuchmatrixlastnight
I blame all my illegally carried forward deductions on deja vu
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
