charles?
theres only 2 yellow gt-ts in vic, charles and alvin
oh okay must've been him then, sorry gaiz i'm still a noob :P
couldn't wave lol was eating a kebab at the good ol' kebab joint. enjoyed eating while watching him do a skid onto springy rd ;)
Edited by r34abz
That doesn't sound like Charles... or Alvin for that matter... Both their cars are too slow for skids ;)
haha must've hit boost. :P
in other news, saw a merc cla on the road today :O
measured up the ass end of the 32 today... coupe tail lights and rear bar are very doable.. not sure if i should.. and if i do ill do it properly and mate up a sedan and coupe boot lid..
f**k
Yeh there's a few already, I've driven a couple now. They are just play around cars for the techs and media
hope your build goes through mate, wide body's are so rare now-a-days.
Fuark nice! How's the car man, compared to your C-Class?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
