What experience/qualification needed?
book-keeping maybe?
obvious sarcasm is obvious.
Glorified PA skills required
Haha
Previously experience mainly in the use of MYOB. Knowing it inside out
I don't think you need a qualification to become a book keeper. You just become one lol
Haha
Eh...I know Quickbooks fairly well. Assume MYOB is the same shit in a different setting? What's pay like for bookies?
wallan isn't THAT far...
if it saves you close to a grand i think you can man up and pay the $30 in petrol :P
yeah wallan isnt too bad!
think how nice the drive back would be also with a nice 100K service done :D
Graduate accountants are pretty poorly compensated themselves if I recall correctly, so I expected their unqualified and glorified PAs to be on much less. If it was out east I'd consider it just for something to do while I look at longer term jobs, but that city travel makes it seem a bit unappealing.
yea i think, dont quote me, but they are on clerks pay scale. so its shite money.
Yeah anyone can be a book keeper. Doesn't use much brain power
Yeah, Grad accountants these days would be around $40,000 p.a
Book keeping position available at my work if anyone is interested
I want.
Going to do MYOB course soon so it'd be perfect way to learn the ropes, PM your work email address, will try to shoot my resume in.
Fark, Leigh gets more than that in his tax return...
Technically that isn't true. That falls below minimum wage, so work there for as long as you want on that salary and keep a log of your hours. When you quit show said log to workplace ombudsman and receive retrospective pay for every hour over 38 inc overtime
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
