lol at wallan posts, I shall have to get back to ya meng. :P
Mate took me to see a 32 gtr today, said he and another mate looked at it yesterday looked nice and sounded healthy and started after needing a jump. Sounded hopeful so I go and see it...it's a gunmetal '90 car, unregistered, been sitting at the yard for at least a year and a half...paint's not bad, body's straight, skirts have rust and mould, windows, seals, spoiler, wheels and rims have mold and lot of rust all over...check the engine, looks alright, half of the leads are out and all seem to need replacing, fmic has massive holes in it and noticed grime, a lot of rust and more mould all through the engine bay surrounds...I just look at him and go, do you have deep pockets? -___- was sad to see godzilla like that tho. :/
sounds like a winner
:P
I think my mate (for it is whom I'm asking for) will also like to be able to tell me in a week or two.
You're planning an interstate purchase soon as well Crispy? Spill the beans! :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
