If it was a factory option only then get your mate to Go to Knox and demand it to be repealed. If not go to formal complaint and add another to his file
+ 1
Don't be like the sheep and say oh well and take it up the anus
A few years back I got stalked and pulled over by Pettitt inside knox (next to the drive through bottle shop near the MultiLevel Carpark / RSL)
He got me to pop the bonnet and went through the engine bay, pointing out things that his junior officer should be checking on any import, how to tell if it was turbo or not, etc... ffs go learn that shit at the academy, stop wasting my time with it!
Ended up getting away with nothing, but it still took 15 minutes of my time and made me late for the movie and I was doing absolutely zero wrong with a completely stock (exhaust only)
*sigh*
Put an official complaint in anyway, say that he was rude and confrontational and would not listen to logical reason about why it is not a defect (standard option for the car).... no doubt the police minister will come out and defend him in the media again saying "To my knowledge, there have been no complaints made against this officer in his time on the force"... when that is complete BS.
and starting at 300,000yen/pax, that is down right ridiculous.
I went to google and typed in "300,000 yen to aud" and the first result was "Is 250-300,000 Yen per month enough to live on?"
*sigh*
So this guys a full blown F&$K wit????
Like import hater???
Mud flaps!?!?!!!
Do you lift Matt?
Judging by your Avatar you do
Awesome pic. Great size. Look thick. Solid. Tight. Keep us all posted on your continued progress with any new progress pics or vid clips. Show us what you got man. Wanna see how freakin' huge, solid, thick and tight you can get. Thanks for the motivation.
Do you lift Matt?
Um........ Glad you noticed? :/
Need to use the currency code, works great
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
