I always like it when a mechanic notices that you've got an interest in cars and actually talks about what and why he changed something for... like shows you the inside of the screwed water pump, or the timing belt cracks etc :P
Also makes payment a lot nicer, knowing that work was actually completed... and WHY it took xxx hours
  • Like 1
This.
I shall take a photo of my old timing belt lol it was cracked as fuark! Apparantly influenced leaks in cam seals so had that all fixed. *phew* Coil packs didn't need changing, already had spitfires, didn't even know! Changed HKS spark plugs to NGK's, hks one's were pretty worn tho. But yeah car just feels amazeballs, due for a reefton run. :D
Reefton Spur, I assume? Have been meaning to go for a ride/drive down that way, but haven't been able to yet. Actually haven't driven / ridden besides daily duties in a long time, lols. Give me a yell next time if you're going up :P
  • Like 1
same here..... daily duties suck.... still get a smile from my car though after 6 months. only thing that kept me smiling longer was my sti.
need to go for a good old fashioned drive soon. or a night drive thru the city. used to love that back home.
  • Like 1
Good weather is approaching
Im sure there will be a few cruises in the coming months
good thing about me having the hsv, is i wont be picked on by the coppers. haha!
inb4 first to get defectd.
just make sure your foglights are off
#@Leigh
haha smart ass :P the funny thing is, I still keep them on because f**k em!
Just got to turn them off if I ever go back to prinny bro' :P
Edited by UNR33L
You know my brothers luck? Got pulled up again, stopped they said he ran a red even though it was just amber didn't give him anything on the spot.
NEK MINIT
Gets 2 fines in the mail, one for red light and 3 points and another for pulling up (when he got pulled over, they didn't say anything) in a restricted zone WTF?!
Dat skyline lyf
Edited by UNR33L
NEK MINIT
Dat skyline lyf
f**ks sake man....
related: I got done for that one about 10-12 years ago at like 4 am sat (was driving modded e30)
cop asked why I ran a red light, told him it was amber when I went through and it was safer to go through as there was no way I could have stopped (truth)
he gave me the fine and points anyway. $200 back then
Then he started to hassle me about what I was doing driving around at 4am in the docklands ( this is back when it was an industrial area)
Told him I was a DJ and off to a $200 per hour gig... dude lost it, I just got in my car and drove off... lulz were had
Dont think it would go that smoothly in 2013 though :no:
yeah we all know they're a bunch of wankers one day they're going to go too far with the wrong person and someones going to get shot or killed over modded car related issues.. my brother is PISSED atm
I kinda want something bad to happen to a stupid hwy patrol cop, they might re-think some of the stupid fines/defects then? I duno.
Edited by UNR33L
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
