Edit: These quotations may or may not have been taken out of context more than the Range Rover vs Bikers story
I don't want my anus peppered or any other seasonings added, I am also a bit worried that you might want to take a bite out of it.
that just means i've got to go to school mega early tomorrow just to draw up a simple piping and instrumentation diagram
i literally have an old laptop you can have. needs external keyboard.
for your visio and shit.
edit, wont help you at the mo tho....
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
