Leave car at home, catch train in?
do not have time have to be there at 7...... plus public transport is for tramps, asians, and hipsters.
and asian hipsters.
nah, i caught train for f1. wont be doing it again ever.
i catch train to work every day and am at spencer st by 7 (it's free if you touch off before 7)
pussy
you enjoy that mate. ill stay in bed an extra 2 hours and drive to work in my own private fart box. rather than sniffing everyone elses. :woot:
also that $50 5 course menu from the vue de monde chef at clayton bowls club was in the age yesterday and it's pretty much booked out till the end of time
did you manage to get a booking in?
ffs my mate was meant to book, but she was waiting for some reason or another... nek minnit it's in the herald sun (as well as the age??) and now it's come to this. pls tell me you're exaggerating :(
Lold at this.
Etihad will be fine for your 10 year old commodore brah
A good parma wins hands down imo, or even a pie and coke for that matter...
Because Hampton Park bogan. :P
  • Like 1
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
