I finished story mode tonight, and sitting on 86% completion... will work my way towards 100% slowly :)
fair effort.
what properties do you own/recommend?
what a beast. so much toob.
http://www.speedhunters.com/2013/10/have-wings-will-fly-inside-the-peugeot-208-t16-pikes-peak/#chapter-making-history
fair effort.
Well you can buy a whole lot of properties with the money that you get from The Big Score near the end, the final heist... and you only need to buy 5 properties for a 100% hurdle... Honestly you're never going to get a lot of income from properties compared to income from heists... But I recommend getting the property with the wooden staircase down to jetty near the top left of the map, this lets you go track down nuclear waste in the ocean at $23,000 / barrel... But as I said, you don't need money in the end...
5 properties eh?
I have 2 bars, los santos customs, smoke on the water and the sonar property. Sonar was a good buy, others arent all that special. Thought maybe some might have had their own mission set or something. All my characters are rerally poor except for trevor who did well on the stock market lol
Note: Los Santos Customs is so annoying being out of the way. feel a bit jibbed only accessible to one shop and one character. oh well, no such thing as a free lunch
Yeah I meant story mode...I'll keep playing and go for 100%, but I get bored easily so we'll see.
Does BAWSAQ or whatever it's called work for anyone else here? Mine always says down for maintenance, wondering if it needs an internet connection to work coz mine hasn't been connected lately..
My mate got to 100% the other day, a lot of time spent finding shit etc
BAWSAQ is linked to the global usage of items in the gta universe, people (players of the game) buy a lot from Ammunation, stock goes up. People blow up a lot of FlyUS planes, stock goes down.
I've been doing stunt jumps and stuff... but something went wrong and now its bugged a bit... Says "undefined" instead of the completion count... so I'm missing 1 of the 50, but don't know which :'(
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
