I finished story mode tonight, and sitting on 86% completion... will work my way towards 100% slowly :)
fair effort.
what properties do you own/recommend?
what a beast. so much toob.
http://www.speedhunters.com/2013/10/have-wings-will-fly-inside-the-peugeot-208-t16-pikes-peak/#chapter-making-history
fair effort.
Well you can buy a whole lot of properties with the money that you get from The Big Score near the end, the final heist... and you only need to buy 5 properties for a 100% hurdle... Honestly you're never going to get a lot of income from properties compared to income from heists... But I recommend getting the property with the wooden staircase down to jetty near the top left of the map, this lets you go track down nuclear waste in the ocean at $23,000 / barrel... But as I said, you don't need money in the end...
5 properties eh?
I have 2 bars, los santos customs, smoke on the water and the sonar property. Sonar was a good buy, others arent all that special. Thought maybe some might have had their own mission set or something. All my characters are rerally poor except for trevor who did well on the stock market lol
Note: Los Santos Customs is so annoying being out of the way. feel a bit jibbed only accessible to one shop and one character. oh well, no such thing as a free lunch
Yeah I meant story mode...I'll keep playing and go for 100%, but I get bored easily so we'll see.
Does BAWSAQ or whatever it's called work for anyone else here? Mine always says down for maintenance, wondering if it needs an internet connection to work coz mine hasn't been connected lately..
My mate got to 100% the other day, a lot of time spent finding shit etc
BAWSAQ is linked to the global usage of items in the gta universe, people (players of the game) buy a lot from Ammunation, stock goes up. People blow up a lot of FlyUS planes, stock goes down.
I've been doing stunt jumps and stuff... but something went wrong and now its bugged a bit... Says "undefined" instead of the completion count... so I'm missing 1 of the 50, but don't know which :'(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
