or dose to work in the "es"? ;)
Gotta go in on the weekend... so the ES must come out of the garage for some sunshine I think! ;)
Also related to above, <3 dilmah. Gonna make some soon and watch new White Collar once it finishes downloading... /currylyf
  • Like 1
haha naice! do want a ride, never seen what an ES is like performance wise, only been in a emo7. :P
hen i must be /sickcurrylyf
I've been waiting 3+ months for my kiwamis- Work nil stock
waited 10 weeks for TE37SL - the day I was going to get my money back and had another set lined up elsewhere - they showed up..
cant decide what size tyres i want to get..
265/275
30/35
not even sure if i want to go for AD08's since i doubt ill be doing track work at all
275/35 or 285/30
Who can help with sending a car panel to UK
Size is 6kg 150cm x 75cm x 30cm Length height width
Its value is only $400.
If someone can find cheap shipping to make it worthwhile ill give em $20. Needs to have tracking
ship2anywhere.com.au is the cheapest i've found.
but your item is pretty large...... sooo.
Edited by xALmoN
Ask whoever sent yours in first place? Or is it 'Australia' tax on postage?
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
