Define "Mid" and what are you using it for?
I'm using it for the weekend of the 8th/9th/10th November... Tempted to buy a Hero 3+ Black edition now actually...
Edit: I would have complete missed that post, but LADY GRANTLY OF HEARTFORDSHIRE saved the day...
Got winton 17th nov. So that weekend??
yeee get that fixed lol.
meanwhile on the topic of silvia's for sale, what in the actual f**k is this http://www.carsales.com.au/private/details/Nissan-Silvia-1994/SSE-AD-2256589/?Cr=22&sdmvc=1
Sydney happened. I lnow it's SA, but still blame sydney
Grant might be interested. :-$
He's deaf not blind
  • Like 1
I have no idea if it's happy dyno, lean or all bullshit from the customer... all i'm saying is get an AFR printout lol
He can't do AFR printouts, the 0-5v input for the wideband isn't working and it would cost $1000's to get the repair tech out. The customer is allowed to watch the AFR display while tuning is going on of course, if they don't have any faith. (If that's the case they should be running their own wideband anyway.)
If you were implying he runs the tunes lean to get more power or that the dyno power figures are massively inflated you are mistaken obviously. I have had some unbelievable tunes from him on RE's dyno, and now his own Dynamic Dyno, smart bloke when it comes to tuning anything. I'm sure you are in good hands Leroy.
Bullshit from the customer? It was Autobarn mate... :P
bro just get these decals. so f**king power. so much so there will be danger to manifold (often realised in floor panels falling apart)
1374712_10153391740145112_2113926151_n.j
fuark how much power is it pushing?? Brian approves :yes:
Different story then... as I said it could have been bullshit... but I honestly hadn't heard a review from someone I would trust until now
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
