Define "Mid" and what are you using it for?
I'm using it for the weekend of the 8th/9th/10th November... Tempted to buy a Hero 3+ Black edition now actually...
Edit: I would have complete missed that post, but LADY GRANTLY OF HEARTFORDSHIRE saved the day...
Got winton 17th nov. So that weekend??
yeee get that fixed lol.
meanwhile on the topic of silvia's for sale, what in the actual f**k is this http://www.carsales.com.au/private/details/Nissan-Silvia-1994/SSE-AD-2256589/?Cr=22&sdmvc=1
Sydney happened. I lnow it's SA, but still blame sydney
Grant might be interested. :-$
He's deaf not blind
  • Like 1
I have no idea if it's happy dyno, lean or all bullshit from the customer... all i'm saying is get an AFR printout lol
He can't do AFR printouts, the 0-5v input for the wideband isn't working and it would cost $1000's to get the repair tech out. The customer is allowed to watch the AFR display while tuning is going on of course, if they don't have any faith. (If that's the case they should be running their own wideband anyway.)
If you were implying he runs the tunes lean to get more power or that the dyno power figures are massively inflated you are mistaken obviously. I have had some unbelievable tunes from him on RE's dyno, and now his own Dynamic Dyno, smart bloke when it comes to tuning anything. I'm sure you are in good hands Leroy.
Bullshit from the customer? It was Autobarn mate... :P
bro just get these decals. so f**king power. so much so there will be danger to manifold (often realised in floor panels falling apart)
1374712_10153391740145112_2113926151_n.j
fuark how much power is it pushing?? Brian approves :yes:
Different story then... as I said it could have been bullshit... but I honestly hadn't heard a review from someone I would trust until now
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
